Winch Mounting Options
Old May 16, 2007 | 10:50 PM
ktmrdr85's Avatar
What do you guys think is the best way to mount a winch? WARN has a few options, the ones that I like best are either the portable option or the grille guard with the winch installed in it.
I see that they also have the hidden/semi-hidden options, but I don't know whether I like that or not.
Old May 21, 2007 | 11:29 PM
ktmrdr85's Avatar
Nobody has any opinions on this huh?
Old May 22, 2007 | 12:34 AM
south_ms_sprcru's Avatar
i kindof prefer the hidden/semi hidden look myself. i have found that brushguards with winch mounts on them end up causing more damage than good (im talking the Warn type, not the much stouter ARB type that is full body armor and meant to take a beating) i have some pics of a hidden winch mount on the f-150 if you want to see that. it depends on what year truck you have as well..
Old May 22, 2007 | 09:37 AM
Bryndon's Avatar
I use a reciever mount, both ends. The front recievers all come out under the bumper, so the winch is VERY low - I cut and redesigned mine to come out above the bumper - cuts through the top of the license plate. 9500# winch - love it and works great.
Old May 22, 2007 | 01:05 PM
Steve83's Avatar
What kind of truck?
Old May 26, 2007 | 09:30 PM
chumFX4's Avatar
I ve seen a few F150s with the hidden kit. Looks real nice! Clean, and all you can se is the fairlead, and the hook coming out. Nice and clean. That is probably what I am getting when I get the $$$
Old May 28, 2007 | 01:07 AM
PhillipSVT's Avatar
On the hidden mounts, If you run a rope you can get a very small and clean looking fairlead without the rollers. Some are even anodized black, so hardly noticeable at all.
Old May 28, 2007 | 01:33 AM
SFAforester's Avatar
If you have an '06 or up, then your options dwindle to...nearly nothing. Warn doesn't make hidden winch setups for '06 and up.
Old May 28, 2007 | 01:48 AM
oh wow, i wasnt aware of that, i thought a hidden mount was available for pretty much every make and model of fullsize truck. check with other winch brands to see if they have a hidden mount available, or call warn and see if they have one due for release.
Old May 28, 2007 | 11:19 AM
powerstroke73's Avatar
I would suggest a reciever mount for a daily driven rig. If you put a front reciever on the truck it will allow you to move the winch from front to back. This comes in REAL handy offroad. Plus when you're not wheeling you can simply pull the winch out of the truck and leave it at home. No need to worry about it being stolen or damaged in an accident. Plus you can easily throw this on anything else that has 12V power and a reciever.
The downside is it kills your approach and departure angles.
Old May 31, 2007 | 02:32 PM
Klitch's Avatar
not sure what year truck you have, heres a couple shots of my trucks semi hidden winch kit. not up real close tho.
Old May 31, 2007 | 02:44 PM
dlandry's Avatar
Hidden, check my sig!
Old May 31, 2007 | 09:45 PM
hunting's Avatar
I have an 07 and have been looking. Not alot of options. Cabelas has one external mount. Klich, looks good!
Old Jun 1, 2007 | 12:52 AM
that hidden mount on dlandrys truck looks great...
Old Jun 1, 2007 | 09:04 AM
dlandry's Avatar
