Sand Ride
Old Feb 27, 2007 | 09:14 PM
fx4jake31's Avatar
Sand Ride
no pics..
had a question. i've got 35/12.5/18 cooper m/t's i live in south mississippi and this past weekend i went ridin on about the only natural beach on between texas and dauphin island and two of my buddies got stuck. the sand was so soft i had trouble pullin myself around and i couldn't pull them out. so had to call this 4 door yukon with 35/13.5/15 toyo mt's and he rolled around out there with ease and pulled my friends out.
i run 65 psi in those coopers cause my last set wore on the corners with like 45psi and the coopers are a load D? i think anyway..
do you think that extra inch width made that much of a difference or was it my air pressure?
Old Feb 28, 2007 | 05:32 PM
Ftruck05's Avatar
I would say air pressure. 65psi thats enough to make the 35's sink like the titanic.
Old Feb 28, 2007 | 07:24 PM
jjbathke2001's Avatar
I run about 15psi in the front and 10psi in rear. i have 35.12.5 r17 m/t sand claws works great for me and i've never rolled the bead, yet,,,
Old Feb 28, 2007 | 09:06 PM
GIJoeCam's Avatar
Yuppers... it's all about air pressure in the sand. Low pressure means more flotation.
As a rule of thumb, measure the sidewall height at road pressure, then air them down until you get to 75% of that measurement. Start there and add or remove air as necessary.
-Joe
Old Mar 1, 2007 | 01:36 AM
bigtruck311's Avatar
i would have to aree air presure, i run about 10-15 PSI in my claws when i am out at the dunes. drop your tire PSI and you will notice a huge diffrense on sand
