anyone ever done a front axl swap?
i havent yet but im gunna soon , i got a set of one ton axles off of a 78
so far i think i will have to add some hangers for the leaf springs... make a new steering system ummm add some leafs so it sits higher, bigger tires alot bigger, ummm new drive shafts
im sure there is a lot that i looked over
For the New body style trucks, I asked this question a long time ago and there was actually a fairly expensive axle swap kit for about $4k (I may be totally off), it was a 4-link susp. kit. To me, it's not worth it unless you're rock crawling on the Moab or up Fordyce. You will never need flex like that unless you're doing those. We get away with IFS out here because most of us are mudders.
I've done a SAS to my truck... you can see all the pics here http://fordtruckworld.tenmagazines.c...38-album-38639
I used a '76 F-150 front axle, Cage Offroad radius arms, Skyjacker 9" coil springs for the '70s F-150, '70s upper coil mounts, heim joint steering, custom fabbed track bar setup, heim joint track-bar.
It works great.
Here's a pic after the swap....
Let me know if you have any questions.
It works great.
Originally Posted by brettmcox
what about a swap on a 2001?
i am looking at doing this to my 99 f150. I have looked at all the kits out there, and they are all the same and of not so great quality. I am designing my own 4 link system right now. I have all the measurements, it is just time for me to put ti all into suspension anylizer, crunch out some numbers, and then draw it up. Hopefully i can finish this project before the summer time comes around, so I'll keep everyone posted.
Check this out
check out these galleries from ford truck world. i would become a member and ask them.
mud's - http://offroadworld.tenmagazines.com...ry.asp?id=3380
bigreen - http://fordtruckworld.tenmagazines.c...ry.ten?id=5338
I have done a SAS on my brothers 89 bronco. It was a good bit of work and I would not recomend it unless you are advanced in fabrication. I will post some pics of the project tomorrow. You can see a few pics at www.xwerx.net
please let me know how your project goes, and give me some tip
