Horn problems????
Old Sep 30, 2005 | 04:03 PM
Fx4man2004's Avatar
Horn problems????
Well a few weeks ago me and a few friends went mudding, we ran through a few mud holes and crap like that. Of course there was mud and water flying in the air and stuff. Well i go and wash it and my horn sounds really high pitched (girly), but after a few weeks its going back to the way it use to be.
Anybody know what could have caused that or if i can fix it or anything.
Thanks alot.
Old Oct 1, 2005 | 09:58 PM
fordtough_k_w's Avatar
my friends 98 does the same thing, iv never had the problem with my 96 but i always thought it might be mud in the horn or somethin that takes time to get out by its self
Old Oct 1, 2005 | 10:13 PM
midnight99's Avatar
It is water in the horns. After a few weeks it just evaporates. I had the same problem, couldnt figure it out and pulled the horns out. When I did, the low side horn poured about 8-10 ounces of water out. I took mine out, and am working on my on board air system to run my train horn.....
Old Oct 1, 2005 | 11:57 PM
ruffn-it's Avatar
Its happened to me a couple times
Just take the horn off and get all the gunk out of it that is clogging it up. Just wash it out with clean water and you should be fine.
Old Oct 3, 2005 | 12:40 PM
GIJoeCam's Avatar
I'm on my 4th set of horns.... mine never seem to come back after they get wet, no matter how long I wait or how many times I try to rinse them out.
This last time, I tried re-positioning the bracket and re-directing the horns to get as little splash as possible.... so far they're still going, but we'll have to see when winter comes.
-Joe
Old Oct 3, 2005 | 01:03 PM
PureCracker182's Avatar
-Joe
I know what you mean. My horn has been completly submerged in water a few times (damn creek crossings) and it never came back. It sounded girly for a few weeks and then it just finaly went out. Now i have nothing until I get my loud ones in.
Brian
Old Oct 4, 2005 | 02:55 AM
Josiah's Avatar
You have to let us know about your air horn progress, will they crack windshields at close range (i.e. car in front of you?) or do any damage to anything? I want them as well so keep me updated midnight.
Old Oct 4, 2005 | 09:34 PM
o dont have train horns yet but we got a set on our show truck , (semi) and they sure are loud, they havent broke any windows but they will break ur ear drums,
ours are pointed to the ground for extra echo and they will shake the pavment
Old Oct 20, 2005 | 10:05 AM
EddyG88's Avatar
Happens to my 04 everytime I go offroad. Usually I lay on the horn for a good 5-10 seconds after and it helps clear it out. Sometimes it gets bad though and the truck sounds like a honda when I "beep".
Old Oct 24, 2005 | 05:07 PM
bigtruck311's Avatar
for a cheap fix to keep this from hapening next time you could keep a plastic bag and a ziptie in your truck, before you go threw the water or go mudding you just put the bag over your horns and use the ziptie to keep it in place, take it off when you are done solves the problem, i always forget to do it untill after i have already been threw the mud tho so it all comes down to remembering to do it before, i just put in some $30 daller air horns from pepboys along with my stock horns they wont break any glass but they are pretty damn loud
Old Oct 28, 2005 | 01:59 PM
Nitro Cowboy's Avatar
My Own Horn Problem
I was making sure My flashers where working on My 97 f-150 and the damn horn starts blowing continuosly. I kill the truck and it keeps blowing. so I pop the hood and disconnect the Neg. it stopped of coarse. But when I reconnected it. it started again. and every time since then. so I am antngsome advice Here.
Old Nov 1, 2005 | 01:57 AM
ruffn-it's Avatar
Do you have an alarm?
