4x2
/\ edit for above...
l
nope......but you'll get stuck (probably,thats when its good to have 4x4 buddies with you)
What kind of off roading you thinking about doing? trails, mud?
l
Once again nothing big at all i dont want to have to worry about getting stuck! id just stick to some trails probably and thats about it. Im getting all terrains put on this saturday (265-70-17) so with those i dont think it would be a problam if i just stick to the trails. I just want to make sure it wont like mess the truck up or something
Originally Posted by f150Lariatc
Is it bad to go off roading with my 4x2 s crew with a/t's? i mean nothing wild just want to go out there and have some fun.
You will need a LOT of momentum, so keep pumping that gas...(seriously). I get stuck in ANYTHING, there is NO weight on my backend, find a fridge on the roadside and load that in there, you shouldn't get stuck as easy
By the way ruffin it, i love ur truck, i see ur going on some trails in ur photos and i wound want to do any more than that really with the 4x2, so what kind of lift did u put on ur truck it looks awsome, maybe the best ive seen on a 4x2.
Thanks for the compliment, it has a fabtech 3 1/2in spindle lift with a coil spacer, add a leaf and a 2in block. basically a 5in lift with 33x12.5 nitto terra grappler A/T's. I have been through some mucky stuff, keeping up with a buddy of mines 4x4 jeep (with 35in mud tires and an 8in lift). Like Josiah says, keep the momentum up and keep turning the wheels (at least in mud).
I have actually never been stuck (knock on wood) but I also am careful where I go, even if that means getting out of the truck and walking into the questionable area. Those "trails" i was on were pretty dry and not that bad so it was no problem. There's just isnt any places in my area to have fun off road.
Hey another question, when i get the 265 70 17's on this saturday, will the tires lift the truck up at all? i had just stock tires before.
Nope, probably maybe a little I don't know what your stock tire size is but it won't lift it enough to be noticable..
