Dana 60 under a Half Ton?
Old Feb 1, 2005 | 05:47 PM
bojenx's Avatar
Anyone know if they make 5 lug axles for the Dana 60 rears?
I just put the third 8.8 rear axle under my 1997 F150 4x4 within the last 9 months, they just can't handle 40" Boggers. So before this one breaks I want to get a Dana 60 ready for the next swap.
I have two Dana 60's ones from a 87 F350 and the others from a 83 F250. I hate to have 5 lugs in the front and 8 lugs on the rear. I could drill the hubs and re-lug em for the 5 lug pattern but i did that once on a 8.8 and it started to shear lug bolts after a while. I had just a hair to much slack in the brake drum holes, so it would shift when the rear brakes were applied. Any ideas where I might find something like that?
Mounting the leaf perches and changing the drive shaft yoke isnt a problem, but the 8 to 5 lug pattern change is whippin' me. Any Ideas greatly appreciated!
Old Feb 1, 2005 | 09:35 PM
powerstroke73's Avatar
Dynatrac makes a rock ready D60 that you can order with 5 lug axles. Its very popular amoung the Jeep guys. The last I heard you could buy the outters from them. Now are these full floaters or semi floaters?
Old Feb 2, 2005 | 09:44 AM
bojenx's Avatar
Man... thanks for the info., I'm goin to look them up right now.
The 83 is a full floater, but the 87 is a semi.
How come it doesn't show my signature below????
Old Feb 10, 2005 | 09:51 AM
JackdUpSilvF150's Avatar
let us know how the swap goes...
I'm interested in hearing about the D60 swap: any particular difficulties encountered, how you got thru them, etc. I've been mulling over putting in a D60 front solid axle conversion and/or a D60 or D70 rear axle in my 2000 F150. I am wondering what problems/issues you encounter when doing the rear axle upgrade because our trucks are so similar.
TIA,
Jack
