Tow hooks
Old Apr 3, 2001 | 03:44 PM
RipF350's Avatar
Question Tow hooks
I'm new to 4x4's so forgive me if this is a no brainer. Why are the tow hooks on the front of the truck? If I'm pulling somebody out I'd think the hooks should be in the back of the truck. Should I be pulling them out in reverse? Also, how are you supposed to attach a closed loop strap onto a closed loop tow hook? Should I use some type of S hook to attach the two?
Inquiring minds want to know...at least this one does.
Thanks,
Rip
2001 F350 XLT SC Dually
V10 * 4X4
Westin Platinum Series Steps
Line-X Spray In Bedliner
Future mods:
Westin Bull Bar
Roll Bar w/lights
CB
Mural on tailgate
33" tires
Other toys:
2000 Coachmen 24' TT
2000 Kawasaki Vulcan 800 Classic
Old Apr 3, 2001 | 03:47 PM
quickdraw's Avatar
Post
hmmm. if you get stuck (hey, it could happen), you may need to be towed from the front. hence the hooks. or you can tow someone in reverse (usually a lower gear than first). in the rear you can pull the frame by use of the hitch/receiver. in the front, tow hooks come in handy.
as for a strap, pull the closed-loop end through the hook and then take the other end of the strap and feed it through the strap's loop. the most secure way to fasten that sucker. can't come off itself or the tow hook.
"flexible hips mean higher steps"
2001 F-150 Supercab XLT 4x4 5.4L Auto w/carpet delete, tow package, power adjustable pedals, law enforcement scanner, CB w/PA, Speedliner, Streamlight Stinger, Graco infant car seat
Old Apr 3, 2001 | 05:28 PM
powerstroke73's Avatar
Post
Well according to some people on the board, "choking" the tow strap is bad. They said that it would result in the strap pulled so tight that you would have to cut it off the hook. I've never seen that happen, every one that I've used like that has always come off just fine. You may have to work a little bit to losen it, but nothing too serious. What I would use though would be a clevice. We use them all the time at Seneca Foods to pull 25 ton pea combines buried in 2 to 3 ft of mud, so they are stong enough. You just have to get one that matchs the strength of your tow strap.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
265/75 R16 Uniroyal Laredo M/Ts
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
Old Apr 3, 2001 | 09:32 PM
bambino's Avatar
Post
I also recommend clevices (clevi?).
One word to the wise, the pin that you can tighten on the clevis - don't tighten it more than enough to just have it stop turning. If you get enough pull power on that thing, they can tighten themself a bit more, and you'll need vice grips to get them off.
These are also good, becuase (on the 150's at least) our tow hooks are closed. The open ones might be the only thing about a chevy truck that i think should be on a Ford.
Bambino Online
Owners Gallery Truck #179
1999 reg cab/short box/ORP - 3.55; 4.6l 5sp; factory snapless tonneau; twin 6" kicker sub tubes; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820-S
Old Apr 3, 2001 | 09:38 PM
quickdraw's Avatar
Post
cleavis
not sure about the plural but it sure is a fun word to say...
"shut up cleavis!"
Old Apr 4, 2001 | 10:41 PM
Crotteau's Avatar
Talking
Hey "CLEAVIS" nice sig, I like the "graco infant car seat!! I myself would like to have the performance red turbo model...
