Modification to Differential Vents
Old Nov 15, 1999 | 02:35 PM
fordification's Avatar
Question Modification to Differential Vents
I have a question for all you off-road junkies, that like getting there trucks dirty. Does anybody know of any specific procedure or possible kits that can be bought to extend the vent tubes on the differentials, so water and other substance don't drain in. I know the rear vent is routed from the axle housing up to the structural member for the box, but I'm not sure where the front diff vent is routed.
a.k.a. flareside @ BON site (non-supporter of his beliefs)
'98 F-150 XLT Reg. Cab Flareside 4x4, Black, 5.4l, 3.55LS, tow package, K&N, GTS headlight covers, Alpine changer w/FM mod, Clifford alarm system w/keyless entry & starter disable // Future considerations: 285/75/r16 Mud Terrain BFG's, bed mat, tonneau cover, 4" suspension lift.
Old Nov 16, 1999 | 12:26 AM
smill's Avatar
Post
Just go to the local parts store and take one of the vent hoses with you. When you get there get some more hose that is the same size. Then remove the factory hose and run the new hose where you want it. I have the rear diff hose routed to the inside of the bed near the top bed rail. The front hose is routed to the top of the firewall uder the hood. Hope this helps.
