Swapping out the whole rear end.
Old Nov 15, 2002 | 02:06 PM
F150NKY's Avatar
Registered User
Ok, i have a few questions and i have not been able to find answers by the search (yea right heard that one before).
As far as all the bolts matching up, can i take the whole rear end out of another 97/98 F150 and bolt it onto my truck (i have a 97 F150 2 WD).
Would it matter if the truck i got the rear end from was a 4WD or a 2WD.
Any help would be great.
Old Nov 15, 2002 | 08:56 PM
BADBLACK99's Avatar
if you figure it out lemme knoe I'm wanting to swap a 9.75 rearend for my 8.8
Old Nov 15, 2002 | 09:14 PM
TexfordD's Avatar
It would be by far easier....
to replace with the same axle,than to try to morf in a differant one
Old Nov 18, 2002 | 09:31 AM
F150NKY's Avatar
Registered User
Yes, i am wanting to stick with an 8.8 rear end. I would just like to find one that is 3.75 and LS.
Old Nov 18, 2002 | 10:21 AM
JBRIII's Avatar
Cost ?
F150,
Can I ask why you want to swap the whole rear? I would think it would be less expensive to do a gear swap and add a powertrax locker to the rear end.
I had an old 83 Bronco as a toy. It had 4" lift and 33's. I swapped the gears to 4.10's and added power trax lockers front and rear. If I remember the approximate cost per axle was as follows:
Gears 4.10's: $150 (Richmond)
Powertrax $300
Labor and parts $200
So for about $650 to $700 you'd have a bullet proof setup. I would guess that swapping out a whole axle would be as much if not more Dollars in toal, because youd have to have it aligned as well.
John
