gear change.
Old Sep 14, 2002 | 10:14 PM
scottie4x4sport's Avatar
gear change.
ok, i'm going to get Goodyear Wrangler MT/R : 315/75-16
(or 34.8x12.3x16) and new Hellcats. (i am getting 3" body lift)
I want to change my gears also. to atleast back to stock gearing.
stock was : 265/70-17 w/3.55 gears
would 4.10 bring me back to the stock gearing?
ALSO
would a step up be a noticable help? I trail ride it alot.
4.56?
thanks
Old Sep 16, 2002 | 03:08 PM
TomatoTruck's Avatar
4X4
I do believe that you will also have to change your front gears as well. It all depends on how much highway driving you do. going from 4.10 to 4.56 is not that big of a jump but it is if you are going from 3.55 to 4.56. basically you are adding a full turn of your drive shaft which will increase your RPM's by about 1,000 RPM's at any speed.
Old Sep 16, 2002 | 03:20 PM
flafonman's Avatar
Gear changes on 4X4s are in fact $X2.
Can't have a 4.10 rear with a 3.55 front.
Old Sep 17, 2002 | 12:48 AM
i am going to change both gears!!!!
why would someone leave one the same???
my question is:
if i HAD 265/70-17 with 3.55's
and now i have 315/75-16 what gear do i need to get to run
the same "FINAL" gearing as before? ? 4.10, or 4.56 ?
Old Sep 17, 2002 | 09:10 PM
Silver&Blue's Avatar
Read My Post!!
Read the post "Formula for regaining stock ratio after tire change".
