NOISE UNDER DRIVER CARPET
Old May 31, 2001 | 01:58 PM
sigmanu1524's Avatar
Red face NOISE UNDER DRIVER CARPET
When I get into my truck to pull out of the parking slot, i hear and fill a noise underneath the car- it almost feels like it is right below my feet. It sound like a grinding noise- what could this be? Do I have struts on this 1999 f150 v8 trition 4x4?
Old May 31, 2001 | 06:56 PM
Ford4ever's Avatar
Post
Hard to tell you the problem without looking at it. You basically have to crawl under and see what's loose or rubbing. look in the wheel well, do you what appears to be a shock inside a spring? If you do then you have struts. I don't think you have them.
-Jon
Old May 31, 2001 | 08:00 PM
powerstroke73's Avatar
Post
Nope you don't have them. 4x4s use torsion bars not struts.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
285/75 R16 Kelly Springfield Trailcutter RTs
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
Old May 31, 2001 | 08:04 PM
kjunman's Avatar
Smile
sig, are you turning all the way to the stops? Have had that happen before. Try lubing the turning stops under truck, this may be your problem.
Old Jun 5, 2001 | 01:02 PM
Post
What are the turning stops?
<font face="Verdana, Arial" size="2">Originally posted by kjunman:
sig, are you turning all the way to the stops? Have had that happen before. Try lubing the turning stops under truck, this may be your problem.</font>
