Overall Crawl Ratio?
Old May 30, 2001 | 11:47 AM
badhabit's Avatar
Question Overall Crawl Ratio?
I was curious if anyone could help me out in finding the overall crawl ratio of my truck. I have a '90 F150 5spd 302ci Reg Cab LB, I believe that the rearend has 4.10:1 stock but as for the T-Case and first gear in the tranny I have no idea. Correct me if I am wrong but don't you multiple all of the ratio's by themeselves for example a truck with 3.55:1 axle gears, 2.0:1 T-case and a tranny first gear of 3.3:1 would have a crawl ratio of 23.43:1. Any info at all is appreciated
1990 Ford F150 XLT Lariat 4x4
5spd
5.0L 302ci
K&N Filter Charger
Hedman Cat with MagnaFlow muffler
Tint
Rhino bed and undercoat lining
100 HC AudioArt Amp w/3 12" Impulse behind the seat
Old Jun 2, 2001 | 08:14 PM
max mitchell's Avatar
Cool
edit
[This message has been edited by max mitchell (edited 06-03-2001).]
Old Jun 2, 2001 | 10:01 PM
acadianbob's Avatar
Post
i believe you are correct, just multiply all of the ratios . . . .
Old Jun 3, 2001 | 02:11 AM
KYFordFreak's Avatar
Post
Yes just multiply the three #'s. A crawl ratio of 23.43:1 is not all that good. According to a sorce I read a 85.1-125.1 is suitable for most offroaders. A few things to to keep in mind.
1. Bigger the motor, less crawl ratio you need.
2. Low ratios are good for rocks, higher ratios are good for mud and sand
3. You can usually run a higher crawl ratio with an AT than MT transmission
IMO, I think the 23.43.1 would be close to what is in my truck and it seems plenty low enough for me. Does anyone know the T-case and AT ratios for sure?
97 Ford F150 XLT 4x4 4.6L auto, Std cab/Long bed, 3.55LS rear axle, PW,PL, and PM, captian chairs w/arm rests
Sylvania Cool Blue Bulbs, Ford logo hitch and license plate, tinted windows, blackouts front and rear(w/ford logos on front blackouts),ventvisors all around, painted logos on door sills and under hood, 55w backup lights, K&N Filter, custom 4x4 emblems, cup holder/LED mod, 99 F150 Triton V8 emblems, and much more to come
Old Jun 4, 2001 | 01:42 PM
JMC's Avatar
JMC
25 Year Member
Post
KYFordFreak,
My crawl ratio is 36.55:1 Yours should be around 26.6:1 depending on your tranny.
Regards
Jean Marc Chartier
SEE us play;
http://www.F150world.com/michapter/
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Jun 5, 2001 | 01:19 AM
Post
Thanks for telling me. I have the AT trans w/OD (which trans is this? 4R70W?). Can you tell me the exact ratios of my tranny and T-case. I think they say that 3rd should be about 1to 1 and OD is something like .71. I have heard that the 4R70W is something like 2.84:1, but you have to also consider the torque convertor has a big effect on this from a standstill (starting out like 7.84:1). Correct me if wrong.
