Transmission Confusion Help
Old May 19, 2002 | 02:09 AM
RAINBOW6's Avatar
I have a 2000 4X4 F-150 with an automatic transmission. Is the "transfer case" the same as the transmission or are they two seperate things. If they are seperate then does the transfer case require its own seperate fluid? Also would this fluid be the same as that used in the front and rear differential?
THANKS.........
Old May 19, 2002 | 12:24 PM
gearmanx17's Avatar
Post
Trans. and transfer case are different units. Eventhough they are bolted together, they fill (with lube) independantly. Check your owners manual for proper type of lube for each unit.
Caution for owners of F-450, with brake drum assy. on the rear of your 5-speed (manual Z/F). This factory drum assembly is bolted to the transmission & fills with lube independantly from the trans.
I have seen horror stories of people replacing their 5-speed (in F-450) & forgetting to refill brake drum assy. (holds about 1/2 qt. of lube). This forgetful mistake usually will cost $1,000 & up (U.S.).
