Front end noise
Old May 17, 2002 | 09:29 AM
ffriskyd's Avatar
Front end noise
When I turn to the right I have a noise that's sort of a "vub, vub, vub" and seems to be coming from the left front wheel area. As I straighten the wheel it goes away and I do not get it when turning left. In addition, the left front tire is also wearing with a cupping pattern on the outside edge. Can anyone tell me what they think it may be? CV joint, bearing? Oh yeah, it's a 97 F150 4 x 4, 4.6. Thanks in advance for any clues.
Old Feb 24, 2006 | 12:19 PM
rickvulcan's Avatar
fornt end noise
I have the same problem, I replaced the steering gear box as it was bad still have the noise. All other front end parts seem okay. It is getting worse as time passes. If you find a fix would you please email me with it.
Thank you,
Rick
Old Feb 24, 2006 | 06:20 PM
The Saint's Avatar
Have you checked the wheel bearings? While you are at it, check your ball joints.
My left front wheel bearing was bad ($150 ish). While changing it I found that my top ball joint was bad.
Just my.02 cents.
Good luck.
