Where to get Precision gears & Auburn LS
Where is the best (cheapest) place to pick up a set of 4.10 Precision gears for a 9.75 rear axle??..........and also an Auburn LS diff. for the same rear end??
thanks
justin
thanks
justin
Check out http://www.lightruck.com for .a distributor near to you. If You live close to Atlanta, I think they have a distributor in Conley, Ga. Good Luck! Gearman
Just_Right,
I don't know how far Statesboro is form Jacksonville, Fl. but Rowland Powertrain put in my 4.10 gears for less than $600. Today they are replacing my borken LS with an Auburn Unit for less than $500. They are a very high quality shop and treat everyone right.
WarEagle
WarEagle
justin-
Nobody sells 9.75" gears cheap. These folks are the most knowledgeable aftermarket distributors that I found.
www.reiderracing.com
WarEagle
"put in my 4.10 gears for less than $600. They are a very
high quality shop and treat everyone right."
>>>>does that include parts too or is that just for labor? If that includes the gears and labor, then I will probably let them do it. Jacksonville is a couple of hours away but i could drive there if the quality and service is real good.
thanks
justin
thanks
justin
