HELP...what do I grease to....
Old Apr 6, 2002 | 01:32 PM
mhussey's Avatar
I was under my truck looking for the rubber boot to insert a grease needle and grease it to stop that annoying squeal when turning. I have been told it was my pitman arm. Where/what do I grease?? Any pics??
Also, I could only find 2 grease zerks on the front end! Are there any more or is the front end of my truck unable to be routinely greased??
Thanks, Matt
Old Apr 7, 2002 | 11:37 AM
T Ellenberger's Avatar
You have found the only two grease fittings on the vehicle.
As far as the grease needle under th eboot; you might try that on the ball joints.
Maybe someone else has more?
Old Apr 7, 2002 | 03:40 PM
max mitchell's Avatar
I have 2 on the idler arm; that's it.
Old Apr 7, 2002 | 10:36 PM
LE PEW's Avatar
I've only got 1 and it's on the idler arm pivot where it bolts to the chassis.
Nothing on the tie rod ends or ball joints.
Old Apr 10, 2002 | 09:59 AM
Icon's Avatar
only replace ment parts come with grease nipples..
get the picture?
money money money, I have to go out and squrm on my belly today and see if I can find some, doughtful.
