Codes on Sticker Inside Door Jam
Old Nov 11, 1999 | 03:07 AM
eriko's Avatar
Question Codes on Sticker Inside Door Jam
Is there a site that has a list of color codes, axle ratio, etc. that helps to decipher the codes on the door jam sticker?
I have seen some info somewhere...but can't remember where.
Thanks in advance,
Erik
Old Nov 11, 1999 | 08:31 AM
cphilip's Avatar
Post
I do not know of one but if you have a place for me to Fax em to you I can get them out of my copy of the factory manual over the weekend and fax em to you. Several pages or more if I remember right. Email me the fax # if you want to do it but someone may come up with the answer sooner.
cphilip@clemson.edu
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels and the 4X4 decals, MODs so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps, Bosch platinum + 4's.
Old Nov 12, 1999 | 11:07 AM
eriko's Avatar
Post
Thanks a lot for the offer...but I hate to take up your time!
I will call the dealer and maybe they can help...after all, it's their job...right!
Regards,
Erik
Old Nov 12, 1999 | 02:34 PM
cphilip's Avatar
Post
Just LMK if I can help. Can snail mail it as well if you need me to.
Old Nov 13, 1999 | 04:46 PM
eriko's Avatar
Question
Here is what the sticker on the door says:
KM 74
Exterior Paint RC | DSO
WB: 119
BRK: 4
INT TRM: 12
TP/PS: blank
R: blank
axle: H-6
TR: E
SPR: 1-5
Can anyone decipher these?
What I am looking for is:
The paint codes...what stands for what?
The rear end...gear ratio & limited slip?
Also on the paint...does anyone know what the name of the bright blue paint is?
Thanks,
Erik
Jacked '97 Expedition XLT 4x4,5.4L,4" Trailmaster lift, 315-75-16's on 16x8 ASA rims, K&N filter, Smittybuilt sure steps, Kenwood Excelon CD w/ 10 Disc Changer, Zapco amps, KEF seperates, Boston Acoustics Pro-10" sub and lots of future plans...will work for truck parts!
[This message has been edited by eriko (edited 11-13-1999).]
Old Nov 16, 1999 | 01:38 PM
cphilip's Avatar
Post
Unfortunately I didn't realize this was an Expedition until your last post. Some of the codes for the F150 are not going to correlate well with the Exped. but some info I got might help. For instance I think your exterior paint code is actually the KM you reported. KM in the F150 manual is called "Royal Blue". The DSO stands for "Domestic Special Order". The RC I do not know any code in the manual that matches and I cannot be sure exactly where you took it from but the paint code is actually above the words "paint code". Is this a two tone? Two tones have two sets of paint codes but they both should be just above the words paint code. WB is wheel base and you must have a 119 inches on this one. Axle codes are different for the F150 for instance H9=Limited slip, 19=3.55 etc. I do not know what H6 is in the Exped. Interior trim is also not a match in the for any of the number combinations in the F150 manual. Springs, well... each one corresponds to a long string of numbers that tell someone exactly which spings were installed again specific to the application. Sorry but you will need the exact manual for these as the codes are in some cases not duplicated in the F150.
Old Nov 17, 1999 | 02:05 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Post
eriko, have you checked out
http://www.scomm.net/~smithm/index2.html
Old Nov 22, 1999 | 07:50 PM
castines's Avatar
Lightbulb
Eriko, the H6 code is a 3.73 rear.
Old Nov 23, 1999 | 10:51 AM
eriko's Avatar
Thumbs up
Thanks for everyone's feedback...Let's close this one and move on to new territory!
Erik
