gear ratios???
Old Apr 9, 2001 | 08:40 PM
therock's Avatar
Question gear ratios???
My brother ha a 99 F-150 4.6L. he bought it used, how can we tell wether it has 3.38 or 3.55 gears L/S???
Old Apr 10, 2001 | 08:30 AM
max mitchell's Avatar
Cool
Get the axle "code" off of the sticker inside the driver's door and search the codes here or post it -or- crawl under and get the "actual" code off of the rear end cover (a tag on one of the cover bolts).
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Apr 16, 2001 | 08:06 PM
Stan9106's Avatar
Question
Excuse me for being and ignorant rookie, but where do I go to search for axle codes? Mine is H9. Thanks
Stan/Red 1997 F-150 XLT Supercab
Old Apr 16, 2001 | 08:15 PM
Barto24's Avatar
Wink
Put the rear end up on jack stands so the tires are off the ground, turn the truck on and put it in drive, if both tires spin you got the limited slip, right????
Well that would work wouldnt it? but it would probally be easier to just get the codes off the net somewhere, and im wonder too how you do that. Thanks,
Brian
98 F150 XLT Supercab 4X4
4.6L V8 3.55LS
Tonno Cover, Brush Guard, Dukes of Hazzard Dixie Horn, 2 150 watt KC Daylighters, Cobra CB Radio
http://hometown.aol.com/barto24/brianstruck.html
[This message has been edited by Barto24 (edited 04-16-2001).]
Old Apr 19, 2001 | 07:10 PM
Stan9106's Avatar
Lightbulb
I found a chart of Ford axle codes at www.ford-trucks.com/articles/axlechart.html.
The axle code can be fond of the drivers side door-jam. Hope this helps
