Gear selection help/advice
Old Mar 30, 2001 | 06:08 PM
5150PhD's Avatar
Question Gear selection help/advice
As you can see from my mods I have a 3.55LS. I would like to get some better low end grunt and was considering new gears, while keeping some drivability (at highway speeds). Should I get the 3.73 or 3.92? I feel that the 4.10 might be to extreme for what I'm looking for. Also what kind of costs are we looking at for installation?
Another question is how does the gears compare to the superchip?
Any advice or information would be appreciated. Thanks
2000 2W F150 (Flareside Black ExCab) 5.4L (3.55LS) with K&N FIPK,Crazyabout150's JetChip *thanks*,Custom phenolic TB spacer, Flowmaster Delta 40, Twin dual 3" pipes out the back, BioLight Xenon Lamps (cool blue), Blazer 55W projector fog lamps, and Stock Ford Sport 17" Rims. Check out the site for spacers that I'm making and other install pictures. http://communities.msn.com/EnvironmentalDamageInc
Old Mar 30, 2001 | 09:45 PM
Ian N's Avatar
Post
Check out comments on https://www.f150online.com/f150board...ML/000851.html - with 4.10's and 17" package, I am turning 2100 rpm at 60 mph in OD, so if anything my drivability is better.
There are no 3.92's for the 9.75" axle only 3.30, 3.55, 3.73, 4.10 or 4.56.
As far as the gears vs chip: the chip increases power but the gears make the best use of the power that you have, letting the engine get closer to its torque peak in normal driving. Changing to 4.10's made my truck feel like it has an extra 25 hp even though it doesn't.
Cost seems to be 600 - 800 installed.
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip
Old Mar 31, 2001 | 09:32 PM
max mitchell's Avatar
Cool
A change of .25 or so is not very noticeable or cost effective. Going to 4.10s from 3.55s is a great change. There is plenty of top end for them with the OD gearing. I got a quote of $550???
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Apr 2, 2001 | 07:13 PM
5150PhD's Avatar
Post
I guess I've been used to crusing at 70+ at 2100 rpms, and seeing 60 at 2100 spooked me a bit. But in the overall picture, not too bad.
Max..Let me ask you a question. How's the 4.10's when it's wet out? Do you find yourself spinning out (like the gas is too touchy)?
Ian...Why no 3.92 gears? Just curious, it seems to be a popular gearing.
Thanks again for your input guys. I think I'm trying to scrap together enough for a superchip first, and then save for the new gears (man I hate having to be patient)
I'll post whenever I get something.
Old Apr 2, 2001 | 09:34 PM
Thumbs up
I've driven many different vehicles with low gearing (high number); some with twice that horsepower. I haven't ever had a vehicle that "the gas is too touchy" for me. LOL
