What is involed in installing auburn locking diff
Old Mar 13, 2001 | 07:36 PM
Clarkbar's Avatar
Question What is involed in installing auburn locking diff
Hello All.
It's been quite a while since I posted, had a bad accident and was without my truck for three months. Well I'm back and have a question, exactly what is involved in installing a auburn locking diff? Is this the same thing as a limmited slip diff. I am tired of one whell burnouts and traction issues in general. What I need to know is that is this a good job for a backyard weekend job or should this be left to a seasoned professional. I will have the help of a mechanic if I do this but I dont want to get in over my head. Most of my experiences have been with super simple bolt ons. A how-to would be helpfull. Thanks guys.
Jim "Clarkbar" Clark
Jim Clark
1998 F150 STX
4.6L Reg Cab
Short Bed
Mods coming soon
Old Mar 13, 2001 | 09:26 PM
nomo's Avatar
Post
Glad you (and your truck) have made a recovery & can join us again!
The Auburn unit is a bolt-in replacement of the OEM diff.
Auburn only has a couple of kinds of diffs- a spool & two different "limited" slips. To my knowledge, they sell neither a "no-slip" nor a "locking" differential.
Old Mar 13, 2001 | 09:52 PM
Clarkbar's Avatar
Cool
Thanks, this is where I found the locking diff. What is the difference between locking/ls ect? thanks again.
On another note I will post before and after pics of my truck. A good bodyshop can do wonders. I am incredibly picky and I am completely satisfied.
locking diff
www.steeda.com/store/-trcatalog/auburn.htm
cut and paste this in browser let me know what you think
Jim Clark
1998 F150 STX
4.6L Reg Cab
Short Bed
Mods coming soon
Old Mar 14, 2001 | 12:25 AM
gearmanx17's Avatar
Unhappy
My professional opinion would reccomend, if you have never set up a differential; pay a professional to do the carrier change. I have seen many horror's (whining diff's, that were not adjusted properly when changed from one carrier to another type of carrier). I have been doing gear work since 1979. Many "do it yourselfer's" think, "no big deal" just pop this carrier out & throw the new one in". How wrong that assumption is! Careful attention needs to be given to backlash (distance between ring gear & pinion) & diff. bearing preload when changing or disturbing any differential bearing. If you set the diff. side brg. preload too loose; your diff. may thump when you take off or shift gears & probably will fail soon. If you set the diff. side preload to tight; diff. side brg's. will probably make noise almost immediately, over heat, fail & then you have a trashed rear diff. assembly.
Differentials & transmission are two of the most overused, abused & undermaintained components on vehicles. For example: I have seen many truckers with 750,000 to over 1 million miles on a class 8 truck diff. or transmission. Trucker sometimes cannot understand why the unit failed?? However, he generally hauls 80,000 lbs. when driving this vehicle & usually never changes lube in trans. or diff. Point of story, mechanical components do wear out. Preventative maintenance & user respect will make these components last much longer & you the owner will vastly benefit.
Thanks again Steve, for giving us the opportunity to help fellow members & friends!
1999 Teal Blue F-150 S/C
4.6L, XLT, 3.55 L/S 4x2
Tow pkg., Rhino liner, Engine block heater & Swiss hard toneau cover. Premium sound
255/75 R16 Generals-owl
This" is Mama's pride"
Old Mar 14, 2001 | 06:53 AM
Flats Man's Avatar
Cool
Gearmanx17 is giving great advice. I just installed an Auburn pro at a Mustang Speed Shop where they install about 5 Auburns/month. I took detail photo's of the install which I will post soon. My gears are quiet and were done very professionally.If you are considering a lower gear change, you should do it at the same time as the Auburn. Be prepared for increased wheel hop and axle wrap though! With 3:55 gears I had no problem but with the 4:10's and the Auburn it really jumps. Good Luck!
"The Beast" 98 White 4.6 Triton STX (It's not an STX anymore) Flairside,Class III hitch, Blue Cobra Stripes, Euro Lid by Astro, Bed Rug, Fiero Wing, Air Dam,Ground Force 2-4 Drop,Custom MB Phantom Wheels,clear corner lenses,monster battery terminals,MTX Sub Box with 2 10 inch Polk Subs, 4 Polk Speakers, MTX 102 Amp with Pioneer FH-P4400 CD Cassette Head Unit,Custom Programmed Super Chip,BBK 75mm TB, Pro M 80mm MAF,Pillar Pod w/ boost and trans temp,Jacobs DIS Ignition,Art Carr 2000-2400 stall transmission,4:10 gears with Auburn Pro Limited Slip,custom rear end housing, custom intake tube, Jet coated JBA stainless headers, custom Y pipe after the Cats, Magna Flow Muffler with Stainless Duals and of course fully Blown by Magnacharger!
http://www.zing.com/album/?id=4293450711
[This message has been edited by Flats Man (edited 03-14-2001).]
Old Mar 14, 2001 | 09:06 AM
max mitchell's Avatar
Cool
Clarkbar- It required a few specialized tools and experience to accomplish professionally. It requires a substantial tear down. The Auburn unit uses a different design from the OEM unit; cone clutch instead of plates www.auburngear.com/aftermarket/products/differentials/ If you do a browser search there are tons of websites that show Mustang 8.8" installs: setup, bearing separation/pressing, R&P shimming, etc.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Mar 14, 2001 | 01:02 PM
nomo's Avatar
Red face
Hope I didn't cause too much confusion with my "bolt-in" statement. All I meant was that no special gears or housing was necessary.
It does take substantial knowledge & practice to do this stuff RIGHT! I had a 4WD shop do mine... very quiet and minimal "chatter" when turning.
Steeda has mis-labeled their Auburns as "locking" diffs- they are not.
Old Mar 14, 2001 | 01:26 PM
Clarkbar's Avatar
Post
Thanks for all the info. If I was to do this I would want to do it the right way. I dont have much experience with stuff like this so if I decide to get a LS Diff, I will have it professionally installed. Thanks guys.
