2001 SUPER CREW Differential Problem?
Hey,
I just had to have my rear differential replaced on my 2001 Super Crew truck.... it started howling really bad, and it turns out the pinion gears were shot and I had to have to whole thing rebuilt. I thought is was a freak thing, but now I know 3 other guys that had the same thing go bad. Anyone else out there have this problem? Anyone heard of a possible recall. I got screwed being over the warranty mileage, but I know some guys had to replace already around 20,000 miles... that just doesn't sound good.
Thanks.
Mr. Iowa
Thanks.
Mr. Iowa
I suspect that many of the differential problems on late model F-150's could possibly be from lazy people de-burring the axle housing (center section) of the differential assembly in the manufacturing process. ARE YOU LISTENING--FOMOCO PEOPLE?
By the design and quality of the internal components of OEM ford differentials, I cannot see any other reason for rear axle assembly failure (other than continued abuse, neglect or human error).
Comparing 8.5" GM rear axle to 8.8" Ford rear axle; 8.5" GM axle fails approx. 30 times to one 8.8" ford axle. Reason why--GM axle is designed weaker.
Yep, 2000 chiming in. Just had all the work done yesterday. 21000 on the odometer. $359.00 parts/labor, but still under warantee.
At least it has the proper fluids for the LS now, because the clutches have chattered since about 1000 miles.
