4x4 only one 1/2 shaft Turning
My 4x4 is not working…I am pretty sure it is the actuators, but jacked it up so all four wheels are off the ground. When I put it in 4x4 the driveshaft to the front difff turns and only the passenger side 1/2 shaft turns. Is this normal?
I was testing that everything worked up to the actuators, but expected both shafts to turn.
I didn’t know the front diff was open. I put some resistance on the passenger side and the drivers side started to turn. Swapped out both iwe and working great now. Thank you!
