Help
Old Dec 11, 2021 | 06:19 PM
Laura 14all's Avatar
Help
!!!I have a 2002 ford 150 crew cab. Use it to pull a trailer 3+ days a week hauling average 1500 lbs. It died on the side of the highway.. Rear end is locked up. Cant get the gear ratio easily. Stupidly had it towed to the ford dealership. They are basically holding it hostage until I pay them a couple hundred dollars for the "examination". Would like to know if I can find gear ratio, and other possibly pertation info before I go in to deal with them. so they don't try to baffle me with bs. Please someone help me.
Old Dec 11, 2021 | 09:35 PM
Roadie's Avatar
There should be a metal tag on the diff cover showing the gear ratio and if it is limited slip. Also the sticker in the driver's side door jam has a code that tells you the same info.
Axle Code
Positraction Ratio B4 Limited Slip Differential 3.73
B5 Limited Slip Differential 4.10
B9 Limited Slip Differential 3.55
If the door jam code doesn't contain a letter it isn't a traction lock rear.
https://www.google.com/search?q=ford...UwbkP_qut8Ao15
Old Dec 13, 2021 | 04:49 AM
HunterBelle's Avatar
I’m not sure about that fee. Did you request they look at it? Doesn’t seem right to just charge people for doing something a customer didn’t request nor get notified of beforehand.
I have a Case IH Quadtrac with a large blade. You’re not holding my truck without a fight 😂😂👍🏼
