3.55 open gears ok w/ 35s?
Old Dec 8, 2021 | 05:10 PM
w00kie13's Avatar
I have a 3.55 rear non limited slip can I run 35s w/ this or should I swap gears? I do a lot of highway driving and if I DO have to swap gears I probably will put a limited slip diff in
Old Dec 8, 2021 | 06:36 PM
Roadie's Avatar
I'm running 32.8" diameter tires on my 02 with a 3.55 gear and it does okay. If I remember correctly it only turns 2200rpm at 80mph. I'm sure 35s would reduce the performance of the truck considerably over stock.
Old Dec 8, 2021 | 07:35 PM
You need to mention which engine, etc.
From your other thread, I see you have a 4.6 3 valve with a 6 speed - I think I'd put 4.10's in it. Remember - with 4wd you also need to regear the front. You are looking at 2 grand to do that, and I would put an Eaton/Detroit locker in the rear, not OEM limited slip.
Do the tires first, buy a programmer and set of custom tunes to correct the speedometer/odometer and optimize the way it runs, and go from there.
