Torque Values
Old Nov 26, 2019 | 10:56 PM
Project Ford's Avatar
Unhappy Torque Values
I recently installed a new cv axle on my 2011 f150. I found most of the torque specs online but I could not find the torque value for the nut on the end of the cv axle that is just behind the dust cover. One other problem I have is that I seemed to have put a very small cut on the inner cv axle boot during installation and there is visible a small amount of grease slightly oozing out. Some help with either of these would be greatly appreciated.
Old Nov 27, 2019 | 09:51 AM
Roadie's Avatar
The cut boot needs to be replaced or it will lead to early failure of the cv joint. I'm not sure about your model but I think the torque of the nut you speak of is low, somehing like 22 ft lbs. But find a manual with that spec before tightening it. It is something like 221 ft lbs for my 2002, but they changed the design in 2004. #not a mechanic
Old Nov 27, 2019 | 05:41 PM
To fix the CV boot, just get a CV split boot repair kit.
DO NOT drive the vehicle while you got a torn boot, especially if it's a new CV. You might as well burn your money.
Looks like this:
https://shop.advanceautoparts.com/p/...9&gclsrc=aw.ds
