leaky rear end
Old Jun 10, 2018 | 06:27 AM
jimbo74's Avatar
5 Year Member
leaky rear end
ok, get your heads out of the gutter :gap:
so, / I recently put on a spectre chrome diff cover on my 9.75"
I have found it to be leaking. I used the paper gasket that came with it, and torqued the bolts to 30 ft/lbs
Going to try and just tighten them up with a ratchet, also going to see if I have an axle breather that may be plugged?
If that doesn't work, should I just redo it with RTV? if so, what color is the best?
A friend of mine, actually said he hates those chrome covers because they warp and leak, has anyone here had that issue with them?
Old Jun 11, 2018 | 07:09 AM
JCR 56's Avatar
I used the grey RTV and it worked good.
Old Jun 11, 2018 | 08:00 AM
I used the grey RTV when I swapped the fluid on my '00 Dakota a couple years ago. Dry as a bone.
If you aren't sure how to make a gasket, go on YouTube and watch a couple videos from mechanics or the manufacturer.
Old Jun 11, 2018 | 09:16 PM
MitchF150's Avatar
Yep, needed to use the RVT... They came from the factory without a gasket.. Just the RVT.
Didn't even know they made a gasket for the 9.75" ??
Chrome cover? Why?
Holds more heat, will just rust anyway...
Good luck!
Mitch
Old Jun 12, 2018 | 07:43 AM
jimbo74's Avatar
5 Year Member
so...... looking @ tearing this apart again.....
might as well spend the couple hundred bucks on an aluminum, higher capacity cover, with a drain plug, and a fill plug, and a sight glass. looking @ the AFE, how is it? anyone using it?
Does the axle have a vent port?
Old Jun 12, 2018 | 11:04 AM
The brake line junction on top of the axle is also the vent port, it should have a hose coming off the top.
