what differential fluid
Old Mar 5, 2018 | 10:37 PM
rmusante's Avatar
What differential fluid should i use for a 96 f 150 4 speed overdrive(5 Speed) manual. 300 straight 6?
Old Mar 5, 2018 | 10:54 PM
Use 80W-90 gear oil. If you have a limited slip make sure to add some XL-3 friction modifier.
Old Jun 19, 2018 | 05:21 PM
John2101F150's Avatar
If you want improved shifting always add friction modifier like Motorcraft XL-3. It is actually an anti-foaming agent!
Old Jun 19, 2018 | 06:44 PM
What does a DIFFERENTIAL additive have to do with shifting?
The TRANSMISSION takes ATF, with no additives. Some people use GM Synchromesh oil instead.
