transfer case and diff fluid.
Old Dec 1, 2000 | 08:19 AM
DaveK's Avatar
Post transfer case and diff fluid.
Can someone tell me what viscosity the fluids are for the transfer case and differential in a '97 ORP? I want to stop at the store on the way home today so that I don't have to make another trip out.
Thanks.
1997 F-150 4X4 ORP, pacific green, 4.6L, K&N filter, DeflectaShield bug shield.
Old Dec 1, 2000 | 09:11 PM
JBRIII's Avatar
Post
You must use 75-140 SYNTHETIC in the rear if yours has a limited slip along with friction modifier. I ordered Redline from Summitracing, along with a trick aluminum cover from TrickFlow. Could not find any of the gear oil locally. Do a search on this topic in this thread and you'll find some interesting info. Very easy to change. Use a gear lube pump and make sure your oil is left in the house to warm up before you start to pump it or it'll take forever!!!
Good Luck,
JBRIII
97 SC XLT 4.6L
K&N Gen II FIPK
75MM BBK TB
Gibson Super Truck Exhaust
Hypertech Chip
Steel Horse Upper and Lower Billet Grille's
Old Dec 4, 2000 | 07:57 PM
Nomopar4me's Avatar
Post
t-case uses MERCON ATF. do not use gear oil in it. you WILL damage it.
Old Dec 5, 2000 | 12:32 AM
Oil Man's Avatar
Post
DaveK,
For your T-case, do not use gear oil in your T-case. The Mfg recommends ATF Mercon. This would be my recommendation during warranty also. If you are hard on your truck, or are not in warranty and want a better oil for your T-case then you can use an oil called Lubrication Engineers (LE) 7500. This fluid has much less wear rates than a Mercon fluid has. It will make your T-case quieter and smoother and will make it last longer.
As for your gear oil. The Mfg. says that you should use synthetic 75w-140 gear oil. I cannot tell you to void your warranty, sy me recommendation during warranty would be the LE 75w140 #9920. A company called Mag-Hytec had some gear oils tested. Some of them are Amsoil 75w90 synthetic, Amsoil 75w-140 synthetic, LE 75w-140 synthetic, LE SAE 90 petroleum. The LE SAE 90 had 22.83 times less wear than the Amsoil 75w-140 and 18.25 times less wear than the LE 75w-140 synthetic. The only reason that I would use anything else other than the LE SAE 90 #607 would be warranty or cold temps, lower than 0 deg F.
These products are sold by a company called Mag-Hytec at 1-818-786-8325
Sincerely, Kevin
Old Dec 5, 2000 | 07:11 AM
DaveK's Avatar
Post
Thanks, folks. I got it changed last night. My local auto parts store stocks Amsoil so that's what I used. One strange thing, though. I pumped out a little over 2 quarts of fluid an managed to put in a little over 2 1/2 along with the 8 oz. of friction modifier. I didn't see any leaks anywhere. Anyone else experience this?
Old Dec 6, 2000 | 02:17 PM
2000F150Fun's Avatar
Post
See my post about the pinion seal failure. Mine was leaking right at the yoke. Suspicious of the liklihood of it re-occurring.
