Coolant flush
Old Oct 27, 2014 | 08:08 PM
scottpav's Avatar
Coolant flush
Can anyone help or suggest link or tutorial to most effective coolant flush? I have a '05 F150 FX4.
Is it necessary to flush or is just draining adequate ?
thanks,
Old Oct 27, 2014 | 10:09 PM
Roadie's Avatar
I always just drain and refill unless I buy an old vehicle that has a rusty system. I use distilled water to mix with the anti-freeze, not tap water. Tap water has minerals that will plate out on the cooling surfaces. I had to replace a heater core one time because I put tap water in the system.
Old Oct 27, 2014 | 10:45 PM
Unless your tap water is very high in mineral content, the additives in the coolant should prevent any corrosion and scale.
