transfer case
Old Aug 31, 2001 | 05:30 PM
gus's Avatar
gus
Question transfer case
does anyone have info on the borgwarner transfercase. how well does it hold up, is it chain driven or gear. how does it compare to the NP 243 or 231 transfercase
Old Sep 12, 2001 | 01:26 PM
Dniles's Avatar
Angry
they don't hold up very well... Mine Broke rather easily on me. I am not pleased....
Old Sep 13, 2001 | 04:16 PM
Tom Kenney's Avatar
Question
Dniles:
Which one did you have, the BW or the NP? And what was the failure?
Mine's a '92, and has the BW 1356, which is chain-driven. I've been worried that this is a weak system, but it seems to hold up OK. However, mine is a 1/2-ton, so I haven't tried to load it up or tow anything.
Old Sep 13, 2001 | 04:26 PM
Dniles's Avatar
Mine is a Borg Warner 4406-24 Manual shift Transfer case... I know it is very similar to the BW1354. One thing I have learned is Take it Easy on your 4WD unless you want to sink ~$2K into your truck.. I don't know it was chain or gear driven... there are a few website that have quite abit of information about these transfer cases. Drivetrain.com is one good one. Good Luck with it and take it easy with your 4WD!
Old Sep 13, 2001 | 04:29 PM
Dniles's Avatar
The Tech at the dealership didn't tell me exactly what was wrong with the Transfer Case just that it was broken internally and it was leaking fluid, and I needed a new one to fix my 4WD. Look for my other POST in the "Other Drivetrain" section... I posted a more detaild post. Good Luck.
Old Sep 16, 2001 | 04:57 PM
gus's Avatar
gus
i had a dodge and it had the np 231 and it was some what weak i never had a problem, then i had a dodge 3/4 cummins and it had the 241 pretty strong . this is my first ford so ill see how it holds up
