rear end whine
Old Feb 8, 2014 | 10:48 PM
jgger's Avatar
Just a guess, but I think somewhere between 500 and 800 bucks. somebody else might be able to help you better with that. I've never had one done, and it will vary a lot depending where you go.
Old Feb 8, 2014 | 10:50 PM
atyates's Avatar
I wonder if I can get one from a salvage yard cheaper than I could rebuild
Old Feb 8, 2014 | 10:57 PM
jgger's Avatar
Probably, only problem is it's a crapshoot as to what you get.
Call around Monday and see what the labor is going for...........I could be completely full of crap on the price.
Old Feb 9, 2014 | 12:50 PM
Roadie's Avatar
The Ford dealer will charge an arm and a leg. Find a good independent shop or a good mechanic who will do it on the side if you can.
Old Feb 9, 2014 | 01:35 PM
aussiekeeper's Avatar
Ring and pinion change will be 5-800 plus bearings. you WILL need bearings from the look at that goo.........
Old Feb 9, 2014 | 08:22 PM
atyates's Avatar
what brand ring and pinion should I get??
Old Feb 9, 2014 | 08:28 PM
Roadie's Avatar
Someone on another post said the Ford dealers are selling rear gears cheap now, depending on the ratio. You can get a 20% discount from on line Ford Dealers rather than buying local. Or just tell your local, what you can get them on line for and they might match the price. A long time ago, the Ford Dealer in Raleigh would give you a 20% discount if you asked. Plenty of guys on the forum have bought gears. Maybe they will chime in. Maybe rockauto.com
Old Feb 9, 2014 | 08:29 PM
Check Fords prices and an independents prices. Depending on your gear selection Ford may be the most economical.
Old Feb 9, 2014 | 08:37 PM
atyates's Avatar
well I might as well go ahead and re-gear. im thinking about going to 4.56.. I just got a set of 34.1" toyos.. so it should get me back to stock, plus a little more low end..
Old Feb 9, 2014 | 09:46 PM
jgger's Avatar
My son bought his from Jeg's. They carry Ford Racing for what it's worth.
Old Feb 9, 2014 | 10:08 PM
Then you'll have to do the front too, assuming you're 4WD. Doing both is some money, especially if you pay for it
Old Feb 9, 2014 | 10:51 PM
I priced 3:55 and 3:73's, the 3:55 gears were $140.00 and the 3:73 gears were around $400.00. He told me Ford was practically giving away the 3:15 and 3:55 sets.
Old Feb 10, 2014 | 11:05 AM
Roadie's Avatar
rockauto sells about 4 different brands with varying prices.
