engine SWAP
Old Dec 12, 2013 | 01:56 AM
fatjay's Avatar
engine SWAP
hey guys have a 92 4x4, 5.0 5 speed
putting in an 89 5.0 out of crown vic.
do I need to worry about putting on my flex plate
Old Dec 12, 2013 | 10:56 AM
Manuals don't use flex plates, they use flywheels. You will need to use your flywheel unless the replacement engine came out of a manual.
Old Dec 12, 2013 | 01:09 PM
fatjay's Avatar
GLC yah I mis spoke, wasn't sure if there would be a balance issue
Old Dec 12, 2013 | 07:14 PM
JMC's Avatar
JMC
25 Year Member
I believe that 1981 was the last year of the 28oz imbalance. In 1982 Ford switched to 50oz in the 302. Check the casting numbers on the cranks. If they match they are the same and you can use the 92 fly wheel.
