Rear-End Clunk
Old Jul 20, 2000 | 06:07 PM
embinns's Avatar
Question Rear-End Clunk
I've had a rear end clunk since I've had my truck. I've mentioned it to the dealer on at least two occasions and received back the ever-frustrating "Could not verify conern." It happens more when it's cold and when I come to a full stop at least a little aggressively. Anyone else have this?
Old Jul 20, 2000 | 06:16 PM
ford-tough1's Avatar
Post
Do a search on "slip yoke" this may be your problem. Give more info on your truck. 4x4,2x4,year, trans etc.
Old Jul 21, 2000 | 08:58 AM
embinns's Avatar
Post
It's a 99 S/C 4.6L 2WD 3.55 4R70W
1999 SuperCab 4.6L AT
K&N Filter
Factory Installed Soft Cover
50-Series Delta-Flow Single-In/Out (currently)
Wish List: More Rumble, 2/4 Lowering, aftermarket shocks to "de-bouncify" the ride
Old Jul 21, 2000 | 11:54 PM
gearmanx17's Avatar
Post
The problem could be loose u-bolts on the springs (at the bottom of the diff.-where u-bolts clamp around axle housing). Also, could also be loose, broken, or defective trans. mount (on the bottom of trans.). Is the trans. leaking @ the rear seal? If so, this could be a driveshaft problem. By you post, I would check u-bolts & trans. mount first.
1999 teal blue f150 s/c
4.6l, xlt, 3.55 L/S
Tow pkg., rhino liner, engine block heater & hard toneau cover. single c.d.
255/75 r16 Generals-owl
Old Aug 20, 2000 | 09:58 PM
kearney5's Avatar
Angry
I too, have had a clunk in the rear end, usually when turning in either direction. I, too, have had 2 "unable to verify" dealings...the truck is a stock '98 4x4, off-road package, 17" wheels, no apparent loose body parts, 5.4l, bedliner, yadda yadda. No other modifications. Anyone else w/ similar probs and solutions???? PLEASE HELP!! Thanks!
Old Aug 20, 2000 | 11:51 PM
csacom's Avatar
Registered User
Red face
I too have a cluck in what appears to be the rear driveline. I get it mostly when I accelerate through a sharp curve or when I start off from a slow or dead stop. I can get it not to make the noise by pressing the gas pedal light and slow. I asked the dealer and he told me that it was "normal". It does seem to be getting worse so I am taking it in on 8/22. If they fix it and I will post what they did. He also told me that "greasing" the yolk will quiet it down for a while.
1997 F-150
Ext Cab
4x4 w/offroad pkg
towing pkg
4.6L with Auto Trans
Old Aug 21, 2000 | 08:53 PM
kearney5's Avatar
Thumbs up
csacom-
Thanks, and please let me know what (if anything) helps. I don't know about you, but I cant stand it when the dealers say "its normal", makes me want to ask - so you settle for a piece of s**t becasue its normal??? Anyhow, thanks again.
KK
Old Aug 21, 2000 | 10:27 PM
redlariet's Avatar
Post
I posted this a few months ago. The lariet had a clunk--starting-stopping-turning--for a year or so. One day, a buddy asked if I knew the spare tire was loose & swinging a couple inches. Nuf said?? The clunk hasn't been back.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-3"
pvc air box mod-Granetelli MAF
Old Aug 22, 2000 | 10:17 AM
rpm9001's Avatar
Post
Try grabing the top of each rear wheel and shacking the rear wheel(enough to get the whole back of the truck rocking hard) and listen for the clunk or wheel movement. If you have either take it to the dealer, neither is good! There should be no play, at least there is no spec for the play. My dealer is replacing the whole rear due to multipal problems inside the rear (In the shop now. good luck
Old Aug 22, 2000 | 11:59 PM
csacom's Avatar
Registered User
Unhappy
kearney5
After spending 5.5 hours watching TV at the dealership today, they told me the "clunk" was coming from the transfer case. They need a WHOLE day to fix it he said, so I have to take it back next Tuesday. It is covered under my extended warranty, glad I got that. But... I will let you know if they actually locate and fix the problem next week.
1997 F-150
Ext Cab
4x4 w/offroad pkg
towing pkg
Old Aug 23, 2000 | 07:18 AM
rpm9001's Avatar
Post
My last post said there should be no side to side play in the wheels, but dealer said the play is normal! checked this on 4 new f150's on the lot and they all had the same play! They replaced the rear before they figured it out! $1100.00 later (ford picked up all but $175.00) now I don't know what to think about the clunk I still have......
Old Aug 23, 2000 | 07:29 AM
selva1's Avatar
Post
I had a driveline clunk that could be heard when coasting to a stop. It could also be heard when I was stopped with my foot on the brake and changed gears (automatic: reverse to drive after backing up, etc.). I have the one piece aluminum driveshaft, and the dealership told me it was unsafe to drive. They replaced the entire driveshaft assembly under warranty, and it's been fine ever since.
Hope this helps,
selva1
Click on any pic below for a closer look:
<A HREF="http://www.zing.com/picture/p8bbc38a6b8da7299901c07d2740149c5/ffaf352e.jpg.orig.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p18dfc566f482837068e8ff7599500eac/ffaf3443.jpg.orig.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/pbe7cf6fd92bd647780a60a53170b215f/ffaf34dc.jpg.orig.jpg" TARGET=_blank> </A>
2000 XLT Sport, Flareside, 2WD, SuperCab, 5.4L. Factory options: 3.55 LS, Class III tow, Dark graphite captains chairs & console w/CD changer, Remote entry , and Slider.
Mod Highlights: Window tint, light covers, Linex bedliner, ARE LSII lid, Flowmaster cat-back exhaust kit, and a Classic Design Concepts front bumper cover.
Wish list: K&N FIPK, Belltech 3/4 drop, rear sway bar, and a SuperChip.
For details, go to: <A HREF="http://home.columbus.rr.com/selva1/f150.html" TARGET=_blank> </A>
[This message has been edited by selva1 (edited 08-23-2000).]
Old Aug 23, 2000 | 07:59 AM
K Kearney's Avatar
Unhappy
Boy, is this ever confusing...wheel play, transfer cases, read-ends...And the mnystery goes on. CSACOM-thanks for the update, and good luck. Please do let us know what happens.
Oh, yeah, and driveshafts too...
[This message has been edited by K Kearney (edited 08-23-2000).]
Old Aug 31, 2000 | 01:12 AM
csacom's Avatar
Registered User
Talking
OK...
After going without my truck for 2 days, I finally have it back from the dealer. They replaced the rear trans seal and the fron transfer case seal. The clunk seems to be gone, but there is still a little play in the driveline... I guess that is somewhat noremal. They said the blown seal was allowing fluid into places that it was not suuposed to be, and that was causing the noise.
Prior to this I did notice an EXTREMELEY small amount of trans fluid weeping from a little tube on the transfer case.
Hope this helps some.
1997 F-150
Ext Cab
4x4 w/offroad pkg
towing pkg
Superchip & Velocity Tube
Old Aug 31, 2000 | 06:21 PM
Kenster's Avatar
Post
I used to have a big thunk upon takeoff and quick stop. One day my wife came in and said
"Honey, you left your bowling ball in the back of the truck again."
