power steering problem
Old Aug 24, 2013 | 01:39 PM
captlou307's Avatar
changed power steering pump,return line an high pressure hose,still having problems ,feels like it sticks while turning an then lets lose then sticks again while trying to turn,any thoughts
Old Aug 24, 2013 | 04:05 PM
sam1947's Avatar
Sounds like the lower steering shaft U-joints are bad...somewhat common problem. Go here: https://www.f150online.com/forums/ar...t-04-08-a.html
Old Aug 28, 2013 | 06:38 AM
gearmanx17's Avatar
Aiir
With the engine warmed-up, pull the cap off the reservoir; if you see champagne bubbles, you have air in the system. To work air out, slowly go from lock to lock (with steering wheel) and air should gradually work out of the system.
Old Sep 2, 2013 | 07:43 AM
captlou307's Avatar
power steering
gearman do I leave the cap off resv while turning lock to lock if there is bubbles
Old Oct 1, 2013 | 10:04 PM
gearmanx17's Avatar
Yes, Leave the cap off while working any air out of the P/S System.
