f150 4x4
Old Jan 30, 2013 | 05:18 PM
Mgardner's Avatar
f150 4x4
Hey I am having trouble with my IWE actuator not engaging when the truck is in 4wd just the passenger side. I think the actuator might be bad?
Old Jan 31, 2013 | 08:00 PM
VTX1800N1's Avatar
http://www.f150forum.com/f72/how-dia...m-esof-186872/
Old Feb 4, 2013 | 09:40 AM
Mgardner's Avatar
thanks that is what I needed
Old Feb 4, 2013 | 02:42 PM
Mgardner's Avatar
I get a little vibration when I accurate but it does not happen all the time. I think it is mainly when I have the steering turned or I have a have load. It is coming from the drive train I think. U joins maybe?
2006
Ford 150 4x4
Extra cab
Old Feb 6, 2013 | 01:43 AM
REDBIRD4rmPHX's Avatar
anyone know anything about a 97 since all i read is about an 06 and the 4x4 system changed or is it similar as far as the failures go? my truck clicks when i turn the switch to the 4hi position and get the 4hi signal on the dash but then when i switch to 4Lo it doesn't engage. found out i had a problem when i was out camping and got stuck.
Old Feb 6, 2013 | 07:33 AM
JCR 56's Avatar
Were you stopped with your foot on the brake, and the transmission in neutral when you tried to shift into 4lo? If not it won't shift.
Old Feb 11, 2013 | 09:18 AM
Mgardner's Avatar
I changed my actuator Sunday it was not that bad of a job. The actuator was bad and the gear were a little wore but I put it back together and it works fine.
Old Feb 11, 2013 | 09:20 AM
Mgardner's Avatar
I think the 07 is the as system as the o6 from what I have read.
Old Feb 18, 2013 | 09:08 PM
VTX1800N1's Avatar
97 is a whole different system. No IWEs.
