Transfer case problems
Old Oct 10, 2012 | 11:30 AM
yamaha225's Avatar
Hi all, My father has a 2002 F-150 with the 4.2 V6, an auto trans and 4wd. He is having some problems getting it in and out of 4wd and I was wondering about changing the transfer case fluid. Just wondering what is recommended to put in. Also are there any other problems that could cause hard engagement?
Old Oct 10, 2012 | 03:43 PM
Mercon V ATF.
Old Oct 10, 2012 | 04:09 PM
yamaha225's Avatar
Ok thanks, Anyone know what case would be behind that running gear?
Old Oct 10, 2012 | 09:34 PM
Floor lever or ****?
Old Oct 11, 2012 | 07:36 AM
yamaha225's Avatar
It's a floor lever. The truck is an XL and has no options whatsoever. The case says borg-warner on it but i'm just wondering what model. And if anyone knows why it would be shifting hard?
Old Oct 11, 2012 | 09:02 AM
I believe it's a BW 4406.
Crawl under with some PB Blaster and start hosing down the linkage. It can and does corrode.
Old Oct 11, 2012 | 10:36 AM
1997 lariat 4.6's Avatar
^this.
Old Oct 11, 2012 | 01:43 PM
yamaha225's Avatar
Ok I looked that case up on google and it looks to be the one. Thanks for that. I will look at the linkage this weekend and see if that looks to be the problem. That would make sense. I figured something was up because my stepdads F-250 which is newer shifts like a dream.
Old Oct 13, 2012 | 04:31 PM
yamaha225's Avatar
Hi guys thanks so much for your help. Sprayed the crap out of the transfer case linkage and now its shifts 100 times better. thanks again guys
