Rear end question
Old Aug 1, 2012 | 01:49 PM
nu-supercrew's Avatar
Rear end question
Pinion seal & cover seal leaking and need replacement.
How can I tell which rear end I have: 8.8 9.75 or 10.25?
axel code B6
Old Aug 1, 2012 | 01:52 PM
If you have a V-6 or a 4.6, you have a 8.8. If you have a 5.4 you have a 9.75. If you have 7 lug wheels you have a 10.25.
All B6 tells you is you have a 3.73 limited slip.
Old Aug 1, 2012 | 02:03 PM
Thanks glc! I tried googling it with no luck. Much appreciated!
Old Aug 1, 2012 | 07:44 PM
There is no gasket on the cover from the factory, they use RTV.
Old Aug 3, 2012 | 05:39 PM
ab46501's Avatar
B6 is the 9.75. I have the same and just changed my pinion seal.
