which gears do I have?
I have a 98 F150 that is four wheel drive with the ORP. It also has the towing package as well as the 5.4. How can I tell which gears I have? Weren't the options 3.08 and 3.55?
Wait for the search index to be rebuilt
The webmaster is busy doing several of the reconstruction steps for the website. When he is finished, a search on gears will give you a couple of good threads on finding gears.
Mine has 3.55. The easiest way for me to find it was to look on the differential plate and write down the numbers all the way around it.
If you have those numbers, then you can easily see the gears. Your's will probably have either 308 or 355 on the plate.
Good luck.
Hunt4Fun
Good luck.
Hunt4Fun
