need help fast
Old Jun 24, 2012 | 07:12 PM
rhat26's Avatar
need help fast
Ok so I know this is f 150 thread but i have a ranger. I recently had to replace slave cylinder which is located in the bell housing of the transmission, so i had to drop tranny. once i got it all put back together i went to start it. when i turn the key over it makes a rapid machine gun like clicking noise and its constant until i turn the key off. I bought a new battery that didnt solve it, i took starter it and had it tested, test showed it was still good. i cleaned and checked all connections but it still makes this sound. i'm lost and everyone ive talked to is lost. any ideas?
Old Jun 24, 2012 | 07:23 PM
Takeda's Avatar
Use the crankshaft bolt, and see if you can turn the crank. Sounds like something is binding the flywheel up.
Old Jun 24, 2012 | 08:02 PM
rhat26's Avatar
I did that everything turns freely but still making that noise. I'm beyond frustrated at this point
Old Jun 24, 2012 | 08:47 PM
how old is the battery? maybe it died?
you have a under hood light? Guess it could stay on and drain the battery down if you're working for a few hours....
Old Jun 24, 2012 | 09:00 PM
Takeda's Avatar
Check the negative battery cable connection to the block.
Old Jun 24, 2012 | 09:01 PM
Takeda's Avatar
He tried a new battery, and that didn't help.
Old Jun 24, 2012 | 09:32 PM
starter solenoid?
Old Jul 9, 2012 | 10:23 PM
DChan415's Avatar
Make sure your block is grounded properly
Old Jul 24, 2012 | 11:44 PM
Edmontonpokerfa's Avatar
Everyone on here is on the same path as me sounds like the starter is staying engaged time for red neck troubleshooting - remove the starter and push start it see if the sound goes away
Old Jul 25, 2012 | 12:26 AM
jbrew's Avatar
Exactly! Well, that will tell what it is, - or what it ain't anyway.
Tie the dogs up, chuck a T-bone.
