Possible bad fuel pump
Old Apr 6, 2012 | 01:33 AM
ssmorsi's Avatar
Folks, I'v searched this forum and tried some of the trouble shooting tips but want to run everything by you guys just to make sure.
My 2001 4.6L F-150 has been sitting on the driveway, used once every 2 weeks or so for the last 3 yrs. I came to start it a few days ago and it kept turning over but not starting. The key security chip is working, battery is charged, all plugs are firing, fuel pump fuse and relay check good. When I turn the key to ON, sometimes I hear the fuel pump priming, other times it doesn't. The times it does prime, the truck fires right up. The times it doesn't prime, engine won't start. When the pump does prime, and while the engine is running, the pump makes a noticeable buzzing sound, much louder than normal. When the pump primes. fuel pressure measures at 42psi in the ON position, 36psi with engine running, and 46psi with engine running and vacuum hose removed. I believe all these are within specs.
My question is this: Is it safe to assume that the pump is going bad and will eventually fail completely? My second question is (and I know this can be debated til the end of time) should I get the Motorcraft ($288) or aftermarket? I have Airtex, Spectra, Carter, and Delphi ($165 - $210) available locally.
Thanks folks...
Old Apr 6, 2012 | 06:07 AM
JCR 56's Avatar
Yea, sounds like your pump is going out. As far as brands go i would get the motorcraft
for reliability,but that's just me. I'm sure there are other good pumps out there.
