f150 rear end
Old Mar 25, 2012 | 09:22 PM
plyramler's Avatar
f150 rear end
is there a way without changing gears to make posi traction on my 87 F150. plyrambler
Old Mar 25, 2012 | 10:03 PM
jgger's Avatar
If you want an actuak LSD dif, no.
You will have to change out the carrier to one that has the Trac-lok or a locker type. That will require you to have to do a set up on the diff. However you can keep the same gear ratio.
If this truck is just to beat up, you can weld the spider gears. But that is a bad idea.
Old Mar 25, 2012 | 10:28 PM
1997 lariat 4.6's Avatar
welding spider gears is about your only way on this if you dont wanna swap parts, but it is a bad idea.
Old Mar 26, 2012 | 02:38 AM
KBrian's Avatar
X2 Because a welded rear end will not want to spin the outside tire a little faster when going around corners, and that tire needs to go a little faster to keep your truck on the road
Old Mar 26, 2012 | 10:29 AM
plyramler's Avatar
thks for ya all quick response, mainly use trk to pull boat about 10 mi or go to home depot need mor traction pulling boat out of water. trk has plenty of power but wants to spin. let little air out and than helped (little) any other ideas to get better traction without going posi rear end. pklyrambler
Old Mar 26, 2012 | 10:53 AM
Put some weight in the bed and some wider tires on it.
Old Mar 26, 2012 | 11:01 AM
plyramler's Avatar
thx i would think with a 4500lb boat hooked to it weight wouldn't be an issue, really dont want to add more weight. boat is heavy as it is. tires might be good idea tho-thks plyrambler
Old Mar 26, 2012 | 01:13 PM
A little trick to try - assuming you have an automatic tranny so your left foot is free, if one wheel starts to spin, hold the parking brake release out and partially apply the parking brake. That might get some torque to the other wheel.
Old Mar 26, 2012 | 11:52 PM
jgger's Avatar
Po man's posi, works good too.
Throw about 4-5gallon buckets in the bed. When you get ready to pull the boat out just scoop them full of lake water and put them in the back of the bed. Once the boat is on dry land just return the water to the lake. Should give you about 250 to 300 more pounds.
