Leaking Trans Fluid Into T-Case
02 F150, Changed the transmission about 3 weeks ago, replaced the front seal on the transfer case, but I still think transmission fluid is leaking into the transfer case, had low fluid, and I believe the transfer case is leaking out the output seal where the drive shaft goes in. I just don't understand why it's still leaking after I've replaced the seal.
