Limited slip question
I don't know how I'd act without my Amsoil
if he wants to run synthetic, get the detroit locker.
Thr trutrac takes a mineral lube 80-90. The literature favors Valvoline.
One caveat is the trutrac is un-preloaded; meaning it's an open diff. under low traction conditions such as ice. Un-preloaded defined: It's like taking the S-spring out of Fords Traction Lock--- a wild race of one tire until there is enough grab to bias enough to the other wheel. They say a LS clutch diff is 2 to 1 in bias, and a Torsen aka Trutrac is 3 to 1. If trutrac had it preloaded, then it would be the best of all worlds. Some Torsens are.
HYPO
FWIW I run a true trac in my 2wd F150. If I have one tire on ice and one on pavement, it may act like an open diff. If I have one tire on hard packed snow and one on pavement, it will act like a LS. And in the case of slipping on ice, tapping the brake typically works. All in all, I love my true trac for the type of driving I do.
Also, I took a road trip this last summer that took me through Moab, Utah. I did some mild off-roading, as much as my stock 2wd suspension would allow. My true trac coupled with some good AT tires left me pleasantly surprised. I went through some mild mud and sand, and I climbed rock steps large enough to scrape the underside of the truck. Not once did I lose traction. Now imagine this setup on a 4wd truck...
http://www.youtube.com/watch?v=ijD9cfAt9Yw
This vid illustrates the braking to set the bias. Also true for all LS differentials .
The one negative I've experienced is the quick hunting from side to side to side traction. For example: When one tire is planted on snow and the other is on ice and snow, and because of this not being preloaded, a tire can quickly race in a spin and it digs a hole. It can be too late at this point to apply the brake to get you out.
I was parked and in some fairly deep snow , and I made that mistake.
In some instances, it's best to apply the parking brake first to prevent that hunting, otherwise you can get a quick tire dig, straight down.
I thought I'd share so you know the expectations of how this works differently than the other type of LS's.
