How much to replace my broken rearend?
Had to rebuild my user ID...so not my first post...
3.73 limited slip 9.75" . Clutches (and I think bearings) are shot at 95K. I've been quoted just shy of 2 grand to fix. I think I need a new TracLoc with a rebuild kit (4 out of 6 bearings, I think. I'm not a mechanic). It grumbles while turning like it's going to blow out and whines very slightly on the straight if you listen carefully. Metal dust on the magnet when I had the fluid changed, hoping I could buy some time, but it just got worse.
Saw the TruTrac on Randy's ring and pinion; heard they click while turning not under load from another mechanic. I called Bruce; he said they were excellent in mud and snow, with better lockup once one tire turns 100 RPM faster than the other.
Any thoughts? 2006 F150 XLT Lariat 5.4
