STILL no 4x4 Checked system NEED HELP
Old Apr 3, 2011 | 10:12 AM
Cypgroup's Avatar
I have a 1998 F150 4x4. It is not going into 4 wheel drive low or high .I have been reading forums all day. Here is where I am so far.
Have voltage on both Actuator solenoids. Ground either ones ground or (return) and actuator works fine in both directions. Vacuum and operation from the solenoids down is working properly by my assumption. Removed the sensor in the differential and pushed the ball in and out while checking with a meter. Works fine. Fuse 23 is good. I am starting to think this only leaves the GEM. No matter what position floor shifter is in there is no 4x4 or low range lights. Does anyone have experience and any insight.
