HELP about tie rod ends and rear axle!
Old Mar 30, 2011 | 06:54 PM
blkstallion's Avatar
I an 04 screw and i bought my truck a year ago and i had my pass. tie rod end replaced and i put 17000 miles on it and it already went out. i do have xd 20s with 305s but i would think they would last a little longer then that did anyone else have this kind of an issue?
Second my rear axle shaft is bent and i dont know what kinda gears i have and i was hoping to save some money and do it myself does any one know much about replacing them, i looked on summit racing and found them but idk if those will work or not i guess i just dont know what to do and in info would help me.
Thanks in advanced!
Jared
Old Mar 31, 2011 | 07:30 PM
MI02SVT's Avatar
not too sure about the tie rod issue someone that knows will prob chime in as far as the axle shaft why are you looking at gears swappin out the shaft should be fairly easy just make sure you got the same spline shaft and you should be golden but i would make sure the housing isnt bent too because then your just replacing that for nothin when you shoulda got the whole axle assembly
