Axel Size, 9.75 or??
Old Mar 24, 2011 | 05:06 PM
HamRadio's Avatar
Ok, here is one for you. My 2004 F-150 door tag says we have a B5 or limited slip 4.10 ratio differential. Good enough but as I have the 163 inch wheel base Heavy Duty my question is what size is the diff? It is a 12 bolt. I have been unable to find out what the code tag means that is under one of the bolts.
Tag reads: L101023F18 on second line: 3V121F
Also on the right side axel tube is a sticker that has the number V121F on it.
I ordered a Mag-Hytec cover, FORD-F 12-9.75 and it is too small to fit. It is 12 bolt but is short side to side. My cover original looks like it might be a 10.25.
Does not make sense to me at all. This is a very early production 2004 5.4L, 3V.
HELP?
Old Mar 24, 2011 | 06:07 PM
HamRadio's Avatar
Thinking...
Maybe the L101023F18 could possible be partially decoded as:
Limited Slip 4.10 ratio 10.25"
The rest is a guess.
Maybe we got lucky and got the bigger differential, a 10.25 instead of a 9.75?
Old Mar 24, 2011 | 07:28 PM
7 lug wheels? That's a 10.25.
Old Mar 24, 2011 | 08:10 PM
HamRadio's Avatar
Yes, 7 lug wheels! That is where I was going....Thanks for the input glc!
Old Mar 24, 2011 | 10:00 PM
chiefFX4's Avatar
heavy duty means 10.25 sterling
Old Mar 24, 2011 | 11:44 PM
HamRadio's Avatar
A big thanks!
You guys are very helpful.
Larry
