Gears and LS.
Gears and LS.
Hello,
Looking to swap out my 9.75 3.55 non LS rear for a 3.73 LS rear. I am wondering what all besides the obvious will be required for me to do this. Will I have to have my computer re-programmed to account for the different gear?
For ref, the truck is a 2005 5.4
Thanks,
Devildog101
Thanks,
Devildog101
Thank you again for the help,
Devildog101
No, it isnt a 4x4. Just 2 wheel drive.
im wanting 4.10's so when i get 35s i wont have any problems. would 3.73's be more of realistic option? and idk which one makes both tires spin when you do a burnout (ls or non ls) but i want both tires to spin so posi trac style i guess. i dont know much about rear end's just some basics. lol sorry to hijack your thread, but they'd probably bite my head off for starting a new thread.. haha i have a 4x4 though, will i NEED to change out my front gears??
With 35's, I would probably go 4.10's. I have noticed that alot of guys go pretty big. If you dont already have it, you would either want a LS or one of the fancier locker units that allow you to lock and unlock when you want.
Also, if you change the rears, you would have to change the fronts to match.
What gear/diff do you have in there now? There is a door sticker decoder somewhere on this forum that will tell you if you have 3.73's and ls already or not.
Thanks,
Devildog101
right now mine are 3.55 and im assuming non LS since only one tire spins. and ok. i need to do it before i get the 35s. right now there 285/70 17s with good tread so im going to run them till i cant anymore. lol
I'd go 4.56's if you want to maintain the same ratio as your stock setup if you have or are going to 35" tires. I have 35's on a 6" lift and I am swapping out my 3.73's for 4.56's. The Raptor, which has 35's stock, runs 4.10's but it also has a 6 speed tranny with different ratios than the older 4 speed. I have consulted a couple of different shops as well as read a bunch of threads here and 4.56's are generally far more recommended with 35's. If you have 33's, then 4.10 is perfect and if you have the stock setup but just want a bit more oomph, then going to 3.73's would be fine. I am also going with an Eaton TruTrac LS. It is gear driven, stout, and seems to have more positive reviews than say the Auburn LS. My truck will see moderate trails and snow so I stayed away from the Detroit Locker. I have a 78 F150 that is more hard core that has a Detroit though and I love it for serious wheeling. If you have the cash, the ARB is a nice setup as well. I had a Detroit in the rear of my 76 Blazer and an ARB up front.
I usually do my shopping on line to get prices then hit a local shop and see if they can match it. I look at Randy's R&P, 4Wheel Parts, and others to see what Yukon and other brands are going for. Then I see what the total price shipped to my home would be. Once i have a total cost on parts I take it to whoever is doing the install, in my case Deetz Offroad or Bayshore Truck, and see how their prices stack up. If it is close, then I go local. I like to keep my tax dollars local if possible.
