Pinion Angle/Fabtech
Ok so i just ordered a Fabtech 6"...I currently have a 1.5" lift shackle in the rear...06 FX4...now for the questions..
are the fabtech blocks flat or angled?
if flat..will i most likely need to shim the rear with the 2 together to avoid the b.s.?
and if i need them how much?
I've done some searching and went through page after page, and didnt find an answer. Kind of want to know now, so i can order shims and they will get here around when the lift does. THANKS!
thanks guys. hopfully it will be here in a week or so, the order got screwed up but is corrected now. I'll report back for sure. anyone know ABOUT how many degrees i should shim to start with if not?
