which master install kit for front axle
I bought some yukon 4.56 gears that I'm looking to get installed in the next month or two and I was wondering if there is anything special about the front 8.8 axle because the gears are reverse cut?
Would it work to buy a master install kit that is used for any ford 8.8 axle such as a mustang? The only reason I ask is there are so many new mustang master kits being sold cheap because people buy them and then never get around to regearing and they are a lot cheaper than finding one specificly for a f150 front. I just didn't know if this would work because of the reverse cut, or if there are differences in the bolts or something I should be aware of.
The 9.75 master install kit is a different story, if you know the cheapest place to get one let me know!
Does anyone know for sure? I know one thing, and that is "reverse install" kits cost more from what I've seen.
here is a description from an ebay seller saying the install kit works for standard and reverse:
Master install kit fits all standard and reverse rotation Ford 8.8 Axles. Includes Timken pinion bearings & races. Timken Carrier bearings & races. Pinion seal, ring gear bolts, pinion nut & washer, all pinion depth, and carrier bearing shim packs. Crush Sleeve. Gear marking compound & brush, Locktite, and differential gasket and/or RTV Gasket maker.
http://cgi.ebay.com/ebaymotors/ws/eB...6404&viewitem=
